| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 17 Junior Member | | Junior Member Joined: May 2005 Posts: 17 | I know that there are no stupid questions, only questions that have not been asked, so, here's mine. I have a "50 chevy 1/2 ton that has vent windows, and my question is this, is it possible to remove the vent windows and re-install with full windows?
Smile much, laugh alot, enjoy life: it's short.
| | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | strummer, If you have a '50 model truck, with vent windows. Either it's actually a '51 & up model, or someone switched doors, in the past. The vent window doors didn't come out until 1951. Does your truck have a cowl vent, on the driver side, between the door, & hood. Do you have pull down, or push button door handles. Anythings possible, but it would be alot easier to find non-vent doors. | | | | | Joined: Sep 2003 Posts: 16 Junior Member | | Junior Member Joined: Sep 2003 Posts: 16 | Ihave 51 doors that I've taken the vent windows out, Made new front window track, installed s-10 power window regulators, work great!! will have to do a little engering & install the right reg. in left door, left reg in right door. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Wouldn't it have been easier to just find '47-'50 doors rather than hack up a pair of the only rare and valuable doors in the entire AD line? | | | | | Joined: May 2005 Posts: 17 Junior Member | | Junior Member Joined: May 2005 Posts: 17 | Spanky, sorry it took me so long to respond ... In answer to your question, no it doesn't have the cowl vent on the drivers side and the door handles are push button ... So what year does that indicate?
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | It was my understanding that all the 50's had the "ventless" windows and the "pull down" refridgerator door style handle.. a 50 with window vents and a push button door handle would suggest to me that somebody scored some later doors and put them on...
...that was, untill you mentioned that you don't have a cowl vent on the drivers side.. i'd guess that the truck is actually a '51 or later.
How are you determining the year of your truck? From the Mfg Plate Serial Number (located in the drivers side door jam) or from the date on the title?
Here's an excerpt from the stovebolt TechTips section: ".. some states titled vehicles by the year they were sold, and not the model year. Since production usually started in September of the year preceding the model year, you may see a title for what you would call a '39 truck, but it says '38 on the title. This can happen easily since it was sold in the last part of '38, but was really a '39 truck. Some states called this a '38 then, since it was sold in '38. I've seen this happen up into the early '50's. You may also see one that was a slow mover and got sold a year after it was made, and titled as such."
See if you can get the serial number off your Mfg plate.. if the plate is still there, and the number is still readable, that will be your best bet as to determining the actual year of the truck.
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Prior to 1952 the door handles were pull down, 52 was the first year with vent windows and push button handles.
If you don't have a cowl vent on the drivers side your cab is newer than 1950.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: May 2005 Posts: 17 Junior Member | | Junior Member Joined: May 2005 Posts: 17 | Ok, now maybe we can get down to figuring out what year this baby is .... the Mfg plate was still there, but had been painted over. After getting it cleaned off so I can read it, the serial number is: 6KPJ 9805. So, can anybody tell me the difinitive year? (at least of the cab ...)
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Use the Search link and look for VIN cruncher. That will decode it for you. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The VIN Cruncher can be found here. Your serial number belongs to a 3100 1/2 ton truck made in Oakland, CA in October of 1952. If the title you have says 1950, that's strange indeed. Next thing i'd be checking is to see if the VIN number on the title matches either your Serial number, or the number stamped on the engine just to the bottom left of the distributor. Some areas used the Serial number for the title number, other areas used the number stamped on the engine. It could be that somewhere in the past a guy had a '50 truck with a good motor and title, and had a good body with a shot motor and no title, and just did the ole "switch-a-roo". The Serial number confirms the cab is a '52, and the fact you have "push button" door handles and vent windows in the doors jives with the fellow that said earlier that those features were found starting in 1952.
| | | | | Joined: May 2005 Posts: 17 Junior Member | | Junior Member Joined: May 2005 Posts: 17 | Thanks all of you for the input ... I've checked the serial number against the vin number on the title ... no match there. I'll check tomorrow and see if I can read the number stamped on the engine and see if there is a match there. If not, I'm not sure what to do. At least the licence number matches!
I think you're right Fumblin, it's got to be the ole "swith-a-roo"! But, I do enjoy a good mystery! I'll let you all know what I find out.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Your average John Q. Law isn't going to go hunting for a VIN number on an old truck like that during a routine traffic stop.. so long as the truck looks like what the registration says it is.. and not alot of folks know the difference between a '50 and a '52.
Now if, god forbid, you were ever in an accident, they may try and check the VIN against the registration, but if it's covered in muck, they may just take a peek and say to heck with it.
The problem you may have is if you ever try to title the truck in another state, or sell it to somebody who does.. alot of states require you to take your vehicle to a highway patrol office and have 'em check the vin number against the title before they'll issue a new title in that state.
If the numbers don't match, you may try and contact the person you bought it from.. maybe they just handed you the wrong title. Thats been known to happen!
| | | | | Joined: May 2005 Posts: 17 Junior Member | | Junior Member Joined: May 2005 Posts: 17 | Hmmmm, come to think of it .... there were a couple of other AD's sittin' along the driveway to the guys house .... Maybe I'll try to get ahold of him, if I can still find his number, and see if that's a possibility. Good idea Fumblin, thanks! But, if all else fails, I'm happy with what I got!
| | | | | Joined: Dec 2003 Posts: 74 New Guy | | New Guy Joined: Dec 2003 Posts: 74 | I found this info posted on another board. Hope it helps: ----------------------------------------- #2, RE: One piece window kit Posted by coilover on Jun-10-05 at 08:58 PM In response to message #0
You are hearing from one of the worlds worst record keepers but I'll pass it on just as I have it. Labeled "Vent Window Eliminater Kit" I have two #'s--Hagan (Carson City, Nv) 775-885-1969 and Hardy 817-228-8824. Hope this helps and if you end up using one from either source let the rest of us know how satisfactory it is. | | | | | Joined: May 2005 Posts: 17 Junior Member | | Junior Member Joined: May 2005 Posts: 17 | well, after checking the serial number found on MFg card on the cab door frame, this is a 1952 3100 built in Oakland, CA. Acording to my pink, no numbers match up and it says it's a 1950. Sooo....Can't seem to get ahold of the guy who sold it to me, I don't think he has a phone. Lives out in the woods ... interesting fellow, but that's another story. Any suggestions where to take this from here? Or should I just play dumb?
Michael
| | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Cheer up, your mirrors and wipers should be there tomorrow or the next day..Everything will settle in just fine..Steve | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Get rid of the tags and registration, then get a len title on it. Just say a guy left it at your place five years ago and he owes you X amount of money and you haven't heard from him and you don't know how to get in touch with him.
Try to find someone that does len titles and they will do all of the paper work for you.
PS. They will have to look at the vin #. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | If your sure the numbers on the pink dosen't match the numbers on the engine, you have a few different options, and i'd tackle them in this order:
#1: Post the VIN from the pink (or if your not comfortable doing that, eMail it to me) so we can determine if the number on your pink slip is an engine number or a mfg tag serial number.
If your number is NEITHER, i've heard of some areas DMV assigning a unique number back in the day.. maybe thats what happened in your case, and the year was determined by the year this new number was assigned.
If thats the case, then there would probably be a seperate number stamped on your truck somewhere.
#1a: If the number on your title ends up being a valid engine serial or mfg tag serial for a '52 (and absolutely isnt the number on your engine) then proceed to step 2.
#2: Go back to the dude you bought this truck froms house and tell him whats up. He very well could have given you the wrong title. If the guy has vanished like the proverbial fart in the wind, proceed to step #3
#3: AD_Pickups suggestion sounds solid, except i'd think you'd at the very least need to know the guys NAME that left the truck in your yard "5 years ago". I'm sure the DMV is going to need the VIN on the truck, and if it's been reported stolen, you may end up on the wrong end of a reciving stolen property charge.
Putting a lien on property usually requires the applicant (you) signing a legal document saying that what you're saying is the truth. The truth is you didn't have that in your yard for 5 years, and you have no idea the origins of the truck. I can't imagine a lien can be put on property without some sort of notification being sent to the last registered owner of the vehicle.. if this guy pipes up and says, "Hey! That truck was stolen out of my yard 2 years ago!" you could end up with some charges filed against you. (fraud, theft by deception, stuff like that)
I'd call your local DMV and see what they say you should do in this situation.. if you decide to commit a crime for the sake of getting a title, make sure the juice is worth the squeeze.
| | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | I called the following #Hagan (Carson City, Nv) 775-885-1969 for the vent window eliminator. The kit is about $100 for both doors and you can check it out on their website: www.haganauto.com If anyone has used this kit or does order this kit please let us know how your experience was. I am really thinking about doing this. | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | Hmmm, rethinking removing my vent windows in the 54. I was driving my 40 F#$% (did not want to say the F word on here) The vent windows have been removed. Noticed all kinds of small bugs on my t-shirt. May be wise to keep them, to deflect bugs.
RT1 | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | RT1 ...
Sounds like you did remove your vent windows. Did you use a kit? Was it complicated to do? | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | I bought it that way, sorry. however i just replaced the drivers window. It looks like they just added the two rails, and with the power windows it mounts solid in the middle of the door. So they are just guides, maybe if you went to the junk yard you could cut some out of different doors. | | |
