Brrrr
1 members (baldeagle), 134 guests, and 0 robots.
Topics128,274
Posts1,058,432
Members48,489
#183004 06/03/2005 3:37 PM
Finally got the vent glass out but the rubber weather stripping around the vent window channel needs to be replace. How is it removed? Is it a difficult job?
Chris
Chris 1955FirstSeries
#183005 06/03/2005 4:19 PM
I've tackled one of my vent window assemblies so far, Chris. My experiences to date are covered in two of the BillyBob log entries that may be of some help to you.
Door of Perception
and
Two-Forty A/C
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#183006 06/03/2005 9:05 PM
Chris, I replaced the glass in my 56 but not the vent windows... figured I leave the cracks and imperfections for character. Anyways, if we presume that the vent window metal frame is similar to the window, I pulled the broken window pieces out of the frame... had to use a narrow screwdriver in some places to pry the glass out (wear eye protection!)... Once out and I scraped any remaining rubber in the channel then cleaned, painted, etc the metal parts. I soaked the new rubber piece in motor oil overnight... the next day I layed the rubber in the channel and worked the glass in place. The oil makes the rubber break down a tad and then when dry seals up nicely. This trick was passed along to me by one of the techs at Checvy Duty. I'm thinking you can use the same techniques for your vent windows.
Larry Bear
55.5 Chevy 3100 Panel
