1 members (Mike Roache),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Finally got the vent glass out but the rubber weather stripping around the vent window channel needs to be replace. How is it removed? Is it a difficult job?
Thanks, Chris
Chris 1955FirstSeries
| | | | | Joined: Jul 2000 Posts: 581 'Bolter | | 'Bolter Joined: Jul 2000 Posts: 581 | I've tackled one of my vent window assemblies so far, Chris. My experiences to date are covered in two of the BillyBob log entries that may be of some help to you. Door of Perception and Two-Forty A/C | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Chris, I replaced the glass in my 56 but not the vent windows... figured I leave the cracks and imperfections for character. Anyways, if we presume that the vent window metal frame is similar to the window, I pulled the broken window pieces out of the frame... had to use a narrow screwdriver in some places to pry the glass out (wear eye protection!)... Once out and I scraped any remaining rubber in the channel then cleaned, painted, etc the metal parts. I soaked the new rubber piece in motor oil overnight... the next day I layed the rubber in the channel and worked the glass in place. The oil makes the rubber break down a tad and then when dry seals up nicely. This trick was passed along to me by one of the techs at Checvy Duty. I'm thinking you can use the same techniques for your vent windows. | | |
