| | | Forums66 Topics128,087 Posts1,056,000 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 96 Member | | Member Joined: Oct 2004 Posts: 96 | I have gotten my truck down to the frame and it is time to start to put her back together. the first problem i am faced with is what to do with the frame. I either want to sandblast or acid bath it. can anyone tell me the pros and cons of each and i am on a bit of a budget. thnx | | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | Do a search of the Paint and body forum. Other than that someone here will be with you shortly.
please hold. | | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | When my truck was down to the frame, a Steam Genie was used to clean the frame prior to painting. Rented it for about $100 for the day--did a fantastic job of taking off old rust/crud! | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Once it is steam cleaned and dry, Zero-Rust it
| | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | I sandblasted my frame , it worked great! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I hired mine sandblasted for $100. | | |
