1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#180717 10/24/2004 5:08 PM
I have gotten my truck down to the frame and it is time to start to put her back together. the first problem i am faced with is what to do with the frame. I either want to sandblast or acid bath it. can anyone tell me the pros and cons of each and i am on a bit of a budget. thnx
I
I Offline
Do a search of the Paint and body forum.
Other than that someone here will be with you shortly.
please hold.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
When my truck was down to the frame, a Steam Genie was used to clean the frame prior to painting. Rented it for about $100 for the day--did a fantastic job of taking off old rust/crud!
Once it is steam cleaned and dry, Zero-Rust it cool
#180721 10/25/2004 11:58 AM
I sandblasted my frame , it worked great!
I hired mine sandblasted for $100.
