4 members (chevyb, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln), 110 guests, and 3 robots.
Topics128,076
Posts1,056,008
Members48,433
#18042 04/20/2002 12:57 AM
I have the gas tank under the seat and the truck has not been started in ten years. Should I pull it out to clean or not before putting gas through it?
#18043 04/20/2002 2:22 AM
At the least, I would recommend draining the tank and cleaning the fuel filter. If you don't drain out any rust, it should be okay.
Fred
52 3600
69 C-10
#18044 04/20/2002 1:41 PM
Unless you are going to keep the truck for a show truck in complete original condition. I would suggest you replace the gas tank with one that is mounted underneath in the rear of your truck to the frame. Gas tanks inside of cabs are a huge saftey concern. Also this way you know you have a new clean tank and good to go.............
37 Chevy 1/2 Ton
86 Chevy Blazer
98 Drudge 24 valve Cummins
One worn out Timberjack
