Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (NJC, 1955 1 Series, Wayne67vert, 1 invisible), 141 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#17925 01/21/2004 3:16 AM
hi i just got a rebuilt carb from tomco for my 1951 chevy 216 truck it runs good but i cant let the choke out all the way and it wont start at all even when hot if the choke valve is open it always needs to be a little closed why is this any suggestions?
#17926 01/21/2004 3:32 AM
It sounds like it is starving a bit for fuel. Have you adjusted the idle mixture yet? That may allow it to idle without the choke.
1951 1 Ton Completed
