6 members (rinemb, 68ironhead, elhippie64, Gdads51, Otto Skorzeny, 1 invisible), 124 guests, and 2 robots.
Topics128,095
Posts1,056,075
Members48,433
Ok folks I have a 216 in the truck. I've timed it on the ball and it runs pretty good. The standard fuel available here is 91 octane. I'm just wondering if there would be any benefit in advancing the timing a bit from standard.
Cheers
Bob
Yes, you will gain a small amount of torque, and better fuel economy. You could probably run a few degrees advanced with no trouble. Just advance it a bit at a time until it pings on grades on hot days and back it off a little bit. You will probably need to re-adjust the idle mixture and speed on the carburator after adjusting the timing for smooth idle.
Paint & Body Shop moderator
Thanks again mate. Will do.
All the best
Bob
