| | | Forums66 Topics128,092 Posts1,056,040 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 5 Junior Member | | Junior Member Joined: Apr 2005 Posts: 5 | is there any way i can tell what year my rear axle is from. I know its from a later year, cause i have a 41 3/4 ton and the driveline is open also the shoes are 11 3/4"length of face?" I need to know caus im gonna replace/repair them thanks | | | | | Joined: Nov 2002 Posts: 59 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Nov 2002 Posts: 59 | 1941 3/4 tons had a open driveline (the rear driveshaft is open and the driveline from the transmission to the crossmember is a closed torque tube type)
Remove your rear hubcaps and look for a number stamped on the axle flange. The LH one should be stamped 41 and the RH one stamped 42. | | |
