| | | Forums66 Topics128,094 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 48 Junior Member | | Junior Member Joined: Jan 2005 Posts: 48 | Another dumb question please - when did the C10 go from hydraulic clutch to cable? My '64 isn't hydraulic so I guess it was a year or two earlier?
Also, my clutch release/thrust bearing is grumbling a little (goes quiet when the pedal is dipped) -in reality am I likely to get thousands more miles or should I be concerned? Can it be changed by dropping the gearbox out from underneath or is it easier to pull the engine?
Many thanks, Limey Simon | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | Drop the box and replace everything,clutch,release bearimg,pressure plate ,etc,make sure to check the flywheel for cracks,etc,have it machined if needed,if your going to do the job .do it right,don't forget the locktight on the flywheel boltsany more questions? | | | | | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | Limey.... '62 had a dual clutch/brake cylinder set-up. '63 and on for many years use a lever set-up. No cables on Chevy trucks for clutches for many years that I know of. Do you have one on your '64? As for the throw-out bearing... if it's not making too much noise you'll get time out of it.. but probably not thousands of miles. Leave the motor in as mentioned.. the tranny is much lighter and easier to remove and replace. It's always best to replace all clutch parts together, but if everything else is in good shape, if you are on a budget, or you don't mind hauling out the tranny... replace just what's needed for now.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
| | | | | Joined: Jan 2005 Posts: 48 Junior Member | | Junior Member Joined: Jan 2005 Posts: 48 | Thanks guys, I'll keep an ear on that release bearing. Box out seems the way to go thanks. To be honest I'm so new to my truck that I hadn't realised it was levers not cable, but it certainly isn't hydraulic clutch. Regards Limey  | | |
