7 members (walter74, KEVINSKI, Hotrod Lincoln, Otto Skorzeny, Shade Baby, msmall, 1 invisible),
92
Mod | | | Forums66 Topics128,269 Posts1,058,401 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Does anyone have a good method on how to clean an oil bath air cleaner? I'm not sure what type of cleaning solvent to use. I'd appreciate any input that you may have.
Thanks. | | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Mineral spirits work well.
Winona 1949 3100 5 Window Deluxe Cab
| | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Yup like 49er says
Please leave it out in the sun to dry or blow it out with air...but be careful for flyin' loose crud | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | Thanks for your help. Mark | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | Take it off,pour out the old oil,wash with kerosene.dry it off put in new oil, Dont overfill or you will get more smoke out the tailpipe than you know what to do with,put it back on.
I like old trucks
