| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#17650 12/13/2003 4:37 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Hi-
Does anyone have the torque specs for the connecting rods, rist pin to connecting rod, mains, and head. with the torque sequence?
I don't have a book right at the moment.
Thanks for the help.
Brent | | |
#17651 12/13/2003 4:39 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | I forgot,
This is for a 1953, 1954 235 with solid lifters.
Brent | | |
#17652 12/13/2003 8:33 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Head Bolts: 90-95 ft-lbs Rocker assembly: 25-30 ft-lbs Main Bolts: 100-110 ft-lbs Flywheel: 50-65 ft-lbs Rod Caps: 35-45 ft-lbs Rod Wrist pin: 7-18 ft-lbs Pressure plate: 25-30 ft-lbs
Remember to oil all bolts before setting torque. Torque wrench calibrated lately? See "235/261 Main Cap" Thread for more info.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#17653 12/13/2003 8:37 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Go to the International Inliners page for head torque sequence. You will find it in the tech tips section. http://www.inliners.org/
#17654 12/13/2003 8:46 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 235 specifications General Bore 3 9/16" Stroke 3 15/16" Compression ratio 8.25:1 Horsepower 135 @ 4000 rpm.
Compression (cranking) 130 psi (min.)
Torque, Lbs Cylinder head 95 Mains 105 Rods 40 Flywheel 60 Rocker arm 30 Bell housing 50
Rods & Mains Rod diameter 2.311" Mains ” #1 2.6835-2.6845" #2 2.7145-2.7144" #3 2.7455-2.7465" #4 2.7765-2.7775" Crank end play .003-.011" Rod side clearance .005-.012" Rear seal diameter 3.875"
Head Valve spring 65 lbs @ 1.844" + / - 10 lbs. Hydraulic lifter 1 1/2 turns Solid lifters .006" in. .016" exh. Intake guide height 1" Exhaust " " 15/16"
Cam Cam gear run out .004" max Crank gear " " .003" max Backlash .004"-.006" End play .001-.005"
Piston & Rings Piston clearance .0006-.001" Ring end gap .007"-.017" Oil ring rails gap .015-.055" Ring clearance in groove .002-.004" " " .000-.008" (oil)
Flywheel Run out .008" max
See the USA in your vintage Chevrolet! My Blog | | |
#17655 12/16/2003 1:30 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Thanks for all the info...
It is what I needed to get this beast back on the road.
Brent | | |
