Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Otto Skorzeny, Gdads51, 55shaker, 1 invisible), 128 guests, and 2 robots.
Topics128,281
Posts1,058,472
Members48,490
#176501 04/18/2005 5:56 AM
Junior Member
Junior Member
I've asked this before and got two different answers. I'm trying to determine the "correct" color of the 235 engine in my 55 1st 1/2 ton p/u. The engine in it was "chevy blue", but it was from a later model (58-62). Personally, I like the grey the older engines came in, and if I can't get a definitive answer that's the way I'm going to go. Also, I'm thinking of powder coating the dash. Anyone have any opinions one way or the other?
#176502 04/18/2005 7:11 AM
Knowledge is limited but... the 216's and splash-oiling 235's were gray. The full-pressure 235's were blue.
47 Fleetmaster, Hotrod 6, 5 Speed
50 Sedan Delivery, 327, 5 Speed
#176503 04/18/2005 11:07 AM
I like the idea of powder coating the dash.
#176504 04/18/2005 3:16 PM
engine colors
powder coat the dash :confused: can ya unbolt the AD dash to put it in the oven? or have ya found an oven big enuff for the whole cab?
#176505 04/18/2005 5:03 PM
You can use a heat lamp to cure the powder coating.
Eastwood Infrared Cure System
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin
"Always do right. This will gratify some people and astonish the rest." - Mark Twain
#176506 04/18/2005 5:10 PM
I knew a guy once that found an intact dash in another truck and had it chromed and then installed it into his own. I thought it looked totally awesome.
#176507 04/18/2005 9:17 PM
V
V Offline
You do not want to powder coat the dash because of the orange peel.PC is great for suspension parts and what not but you dont want it on something you will be looking at all the the time.
Gangster whites and straight pipes.....
#176508 04/19/2005 4:30 PM
Junior Member
Junior Member
Thanks for all the feedback. I really appreciate it.
