8 members (moparguy, baldeagle, walter74, Sjm, Wooley, SmalltownTRKGuy, Sjm, Hotrod Lincoln, 1 invisible),
342
9
Mod | | | Forums66 Topics128,165 Posts1,057,089 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Just ordered a front sway bar kit from ChevyDuty for my 54 1/2...
anyone have any experience installing this that could give me some pointers...
save some knuckles..
Thanks | | | | | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | I just installed a front sway bar on my 51,3100 two weeks ago. took a little more then an hour,very easy to install,no drilling needed.The sway bar is a good improvment in handling well worth it. good luck. old navy 51.......... | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks for the input brother...looking forward to the handling improvement | | | | | Joined: Oct 2003 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 66 | Ditto for Old Navy 51's comment. Chevy Duty will fax you the instruction sheet if it was inadvertently left out of the kit.
You will love the improvement in the steering! | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | does it make hitting the pot-holes feel softer? Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | i doubt it would.
is anybody running a rear sway bar also?
2003 ford lightning 1959 chevy 36
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | wonder if i could get one for my one ton panel?
tony'n weatherford | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Chevy Duty said they are on back order for a week or so...guess that means they probably work..I'll being waiting to see...would like a back one too | | | | | Joined: Feb 2003 Posts: 104 Member | | Member Joined: Feb 2003 Posts: 104 | Try ,patricks ,I got mine from them in five days, also ,I WENT FOR THE HEAVY DUTY TIE ROD AND TIE ROD ENDS ,AND NEW ROLLER WHEEL BEARINGS ,MY TRUCK HANDLES LIKE A NEW TRUCK, OLD NAVY 51 ............... | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Alright everyone, got my sway bar today and yup, no instructions..Called them and they emailed some to me..They definitely are very basic..the picture doesn't show much, and there are two kinds of brackets,a mounting plate adapter and a lower connectiong link bracket..the thing is, they don't tell you which is which..was trying to lay this thing out before crawling under the truck...Looks like it's trial and error time until I figure which goes where | | | | | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | Tony N' Weatherford---- I put a heavy duty sway bar from Patrick's on my one ton about a year ago. It really helped the control ( stock front end). At that time, Patrick's didn't sell a 1 ton bar. After talking to him i decided to order what he had and do some modifing. It was simple; all I had to do was make 2 new mounting plates for the u-bolt connections out of 3/8 plate, adjusting the holes to fit and as I recall, that's all there was to it. It is definately worth the effort. Don | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Hey Blacksmithdon..Does that plate that fastens to the front u-bolts connect to both of them on each side? If so, I've got it figured out, except for trying to get the nuts broke loose..into the WD40 stage now, I've already had too many hernias..Thanks Oh, and by the way, those also hold the lower shock mount, will it come off when I take off the nuts? | | | | | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | The way mine is set up is like this : I made a new plate with a different hole pattern or spacing (appearently the 1 ton has wider springs than a 1/2 ton). I removed the two front u-bolt nuts, leaving the shock mount plate right where it was and placed the sway bar plate onto the u-bolts and then reblaced the nuts that I took off. The sway bar ends are attached to the new plate with two rods and some neoprane bushings. If you are installing on a stock 1/2 ton , you probably don't need to make a plate. Try PB Blaster (walmart) or Kroil on the nuts before you work on them; let the oil soak a few days if they are really stuck.Don | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thanks Don, but it looks like the plate will hit on part of the lower shock mount edge if I put it on the way it is...Been soaking them with WD, and went and bought a breaker bar...One broke loose and the others are stubborn..guess I'll shoot them every couple hours and let them soak overnight and try again | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Sway bar installed...Sure wish I had a garage and an impact wrench...But, a breaker bar and a 3' piece of pipe will get those u-bolt nuts off..Sure am happy with the results though | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | Regarding the rear A/S bar, I put one on my '89 half ton Suburban several years ago. It took just an hour or two and went easily. I don't recall any drilling, but it sure tamed the rear end of that thing.
I got the heaviest duty one I could find.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Been dealing with front sway bar, but was looking at putting on a rear also | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Need the instructions, guys. Got mine from Patrick's, no instructions. Please email, as it's after hours in AZ. Looks like extra parts to me!?!
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | hey cosmo, when you get yours installed how about some 1-2-3 type pix of your work,,,make life easier for all of us that may wanna do the same..thanks..Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | I put one from a '53 panel on my last'49. A friend gave it to me after he put a Mustang II in his panel and it really helped. Had it on in no time.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
