8 members (Barney1951, klhansen, Bill Hanlon, Otto Skorzeny, 1955 1 Series, sron48, Hotrod Lincoln, 1 invisible),
105
Mod | | | Forums66 Topics128,041 Posts1,055,487 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | I am so close now that I can taste the brake fluid! My questio has to do with putting in the brake line on my '50. The section along the frame on the passenger side between the two joints seems to be a bit too long to fit. Is there a trick to getting both ends in without bending the line? I'm hoping this is an easy answer and not another excuse for delay on this project. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Put one end in place but don't start the threads. With one hand grasp the other end and with the other hand gently bow the center enough to get the other end in the fitting. Then start the threads and tighten them. | | | | | Joined: Sep 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2002 Posts: 59 | Thanks. I was hoping that was the case but not brave enough to try without the confirmation. The Stovebolt still goes by the idea that "no question is a stupid question', and I'm thankful. | | |
