5 members (KEVINSKI, FAST55, Hanks custodian, Otto Skorzeny, Rusted Nut), 66 guests, and 6 robots.
Topics128,075
Posts1,056,007
Members48,433
Junior Member
Junior Member
Hi everyone, new guy here, love '67 - '72 trucks. So anyway, I bought a '72 shop manual to help me relace the really screwed up carb on my newly-acquired '72 half-ton. The shop manual shows a lot of stuff related to emission control (anti-deiseling solenoid, vacuum advance control circuit switch on tranny, etc, etc), none of which exists on my truck. Were there California & non-California versions of this truck, or do I have a truck with mixed-year components? Here in New Hampshire, emission equipment rules seem to have been sorta elastic with older trucks, but the state is on the verge of tightening the enforcement, & the rule is whatever came on the truck must still be there. Are your eyes glazing over yet? Sorry.
The nut holding the (old Chevy) steering wheel
Riding in the Passing Lane
Yes there were difference between CA. emission devises & the other states. The problem is these early parts were left off when repair work was done or purposly remove because they worked better without them. You could improvise a system that would close to original. smile
1972 Chevy c10 Cheyenne Super
My 68 has all the old emissions including smog pump. I have not really observed much difference between CA and the rest of the country for emmissions in the 67-72 series. There may be a difference though. Certainly in later years there were different requirements.
There are some variations in smog components depending if it is an automatic or manual transmission equipped trucks. Also 1/2 ton trucks seemed to have more smog stuff than 3/4 or 1 ton trucks.
Check out the message boards at www.67-72chevytrucks.com if you have not already. Someone may be able to help you out.
