5 members (wilbur53, WICruiser, panel fan, GMCJammer51, Hush), 127 guests, and 2 robots.
Topics128,038
Posts1,055,471
Members48,424
#175440 04/13/2005 2:57 AM
I got a mechanical tach of ebay. I is an AC, Dated on side is dec 22 1946. It also reads "registers twice cable speed" Does anyone know what truck it is off of, and to what does the cable end hook to? Is it driven off of the distributor?
#175441 04/14/2005 1:14 AM
I would say driven off the distributor.In 53 on the vett,s the were driven off the generator.so when the belt slipped you got a the bird
dan-pa
#175442 04/14/2005 9:24 AM
Most mechanical tachometers are driven directly off the camshaft or an adaptor on the distributor. There is an adaptor that fits stovebolt engines which was made by Mallory.
Mechanical tachs work just like speedometers, although speedometers read 60 MPH at 1000 cable RPM. Your tach reads 2000 rpm at 1000 rpm cable, which means it was meant to be hooked to a camshaft or distributor, which rotates at half crank rpm. Most tachometers will work with a standard speedometer cable.
The tach on my bike runs through the cam cover to a gear on the camshaft. Most cars are off the distributor though.
Paint & Body Shop moderator
#175443 04/15/2005 2:50 AM
Thanks for the info, both you guys, Now all I have to find is an adapter?
