0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | Got a question about the life of a battery. My wife's Honda Accord is about 5 1/2 years old with 105,000 miles. I am still on the original battery. How long should I expect it to last? | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Thomas,I see you live in my neck of the woods.With our winters here I would say you are lucky to have gotten that much use out of a battery.I would take the car to a good service center and have the battery checked.If its starting to look weak,replace it.Just my 2 cents. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | A good battery that is well maintained could last as long as 6 years... typically they last 5 years...
Get another good one, ie.. a Sears Diehard...
The carparts stores sell cheap batteries with great warrantees, and I can guarantee that you will need to use it, as the cheap batteries usually last 2 or 3 years at best (AVERAGE).
| | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | dale937 has some good advice thomas. I average about 7 years on a battery in my vehicles and I live in a colder climate than you during winter. It depends on how you use your vehicle and how well you keep the battery charged. I have a 10 year old battery in an old truck at the lake. It, and the battery in my boat get a full charge prior to close up in the fall. They are just fine come spring. The ATV is ten years old now and I don't expect that little battery will have survived this winter---we'll see.
If you leave the lights on, and the car not running for long periods, then only drive short distances, the battery won't last as long as one that gets a good charge up all the time.
That's my experience going back many years. Others will tell you differently, maybe, according to what they experience.
Cheers, George | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | If you get more then 5 years out of a battery you are doing good. The average life of a battery in a car is 3-5 years. I would expect this to turn into 2 -4 year average as the newer cars/truck of today are loaded with electonic gizmos.
When you buy your replacement battery(whenever that is) Make sure that you buy as many CCA (Cold Cranking Amps) as you can. Typically the top of the line (depending on Case size) is 750 to 900 amps. Some are even hitting 1000.
Here is another tip for you. Every 12 volt battery has 6 cells. Each cell produces 2.1 volts or more. A fully charged battery should have at least 12.5 volts or more. Get yourself a digital Volt ohm meter (Big box stores have them for under $20.00) and check your batter with the ignition off. Six Volt batters have 3 cells and should be 6.3 volts or more.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
