2 members (TUTS 59, Wayne67vert), 97 guests, and 3 robots.
Topics128,026
Posts1,055,406
Members48,422
#175400 05/16/2005 5:13 PM
I have a 51 half ton I am in the prosses of restoring I have the fram off and notised that the left rear shackle mount is worn. I would like to replace. It is rivited on any sugestions?
#175402 05/16/2005 6:00 PM
Is the bracket (which is, in fact, riveted) worn or is it only the bushing in the bracket? Bushings come with shackle kits and and pressed in place. I changed a rear frame shackle bushing in this log entry on my website:
Framework - Halfway Home
If neglected long enough, the shackle pins can wear all the way through the bushing into the bracket metal but maybe upon closer inspection you may find you only have to replace the bushing. Good luck.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#175404 05/16/2005 6:14 PM
Thanx Joe. I'm gettin' older and forgeting things. Logging what I do to the truck helps to remind me not to make the same mistakes twice . . . most of the time grin
Larry Kephart
Boca Raton, Florida
#175405 05/17/2005 2:57 AM
I kinda thought there was a bushing in there. that will probably fix it (I hope}. it looks like it was driven with a broken shackle
thanks I will have more questions as this is a new project and my first time at it
