| | | Forums66 Topics128,108 Posts1,056,239 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 204 Member | | Member Joined: May 2004 Posts: 204 | Well I learned an expensive lesson today. I bought 4 hub caps today that looked like new but were very dirty. 2 were a lot shinier than the other 2 but I thought that they just had more over spray on them than the others since he paints in the shop. I got home and started polishing and the 2 better ones shined like new money and the original blue and red look awesome. The other 2 didn't polish up at all. I don't get it, they all 4 look like stainless but the 2 dull ones almost look like dull wore out chrome. I guess there are 2 different kind of these caps. I can chalk this loss up to inexperience. I'm usually more careful about buying this old stuff but today I got stuck. I guess on the positive side I have 2 that look like new ones but probably paid too much for them. I guess I'll put the other 2 on e-bay and try and re coop some of my money.
Mike | | | | | Joined: May 2004 Posts: 204 Member | | Member Joined: May 2004 Posts: 204 | Are all outer shells of the '41-'46 hub caps made out of stainless? I tried polishing these 2 dull ones again on the bench grinder with the buffing wheel. They look to be stainless around the edge where they're crimped but they can't be. I've polished a lot of stainless over the last few years and always end up with mirror finishes even on some bad looking metal. These 2 caps won't even come close to polishing up. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Mike - You may have two stainless ones and two chorme plated steel ones. I belive the orig. caps were plated steel. the new repros are usually stainless. You could sell the two steel ones or maybe have them chromed. Just a thought. George | | |
