7 members (Gdads51, Phak1, Joe H, Youngin' Tut 59, Greg_H, carbking, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,137 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1 Junior Member | | Junior Member Joined: May 2005 Posts: 1 | I read somewhere that the best way to lift a stovebolt is to replace two headbolts with eye bolts. Where do I get the eye bolts? | | | | | Joined: Jan 2005 Posts: 95 Member | | Member Joined: Jan 2005 Posts: 95 | It's a lot easier to remove a bolt from the right side of the thermostat housing and bolt one end of a chain with a longer bolt into that hole and then fasten the other end of the chain to the last bolt on the intake /exhaust manifold using a longer bolt there too. I have pulled many stovebolts that way without a single mishap. Jim | | |
