| | | Forums66 Topics128,049 Posts1,055,652 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 2 Junior Member | | Junior Member Joined: Nov 2004 Posts: 2 | Thanks to everyone who provided suggestions yesterday. I removed the motor and took it apart. I greased up the chamber that the paddle moves in. I opened up the passage that I had plugged yesterday. When I reinstalled the motor nothing much happened. The air is being sucked in through the outlet quite strongly, there is plenty of suction being provided from the hose that goes to the engine manifold. The wipers aren't moving. What do you suppose is wrong??? Thanks once again in advance. John Flowers | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Sounds like you might have a crack in the diaphragm.
Fred 52 3600 69 C-10
| | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Honest?
What's wrong is that you've not spent $30 and installed an electric wiper motor
I'm not bein' mean.....vacuum wipers are just plain unsafe | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | And where do you find these $30 electric wiper motors? | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | J.C.Whitney has a couple of universals they sell...if you buy the one for early Chevy it's the same piece but the same
I have had one in the 39 for over a dozen years | | |
