| | | Forums66 Topics128,124 Posts1,056,334 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | Someone once told me the best way to do it was to remove the bed and put the wood in under it. Someone else said u can remove the fender wells inside the bed and just slide them in. How do u actually do it? What are the different ways? What are the pros and cons of each one? I am ready to install the bed but i am curious as to a good way of installing it without scratching the paint. jason | | | | | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | There are seven bolts inside the fender tub that hold it to the side of the bed. Get those, and the carriage bolts thru the bed wood out, and the tubs will lift out of place. The bed sides, and front panel have flanges that the wood rests on top of, not below, and is bolted thru. So there's really no way to install the wood from underneath(that I am aware of) Start in the front corners, and work your way toward the middle plank. Dont drill holes or bolt anything up till you have everything in place and adjusted properly. When re installing the fender tubs (last) position the seven side bolts first, then line up the bolts that go thru the wood, then tighten it all down. Thats how I've done it. Some others may have some tips/tricks as well. HTH | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I left fenderwells attached. I put the rails down, set the bed on top. Then pick up each corner & slide a short board in. Then start assembling other boards & strips. I found a socket that was a good "spacer" as you want to space boards all out correctly before tightening it all down. Brian | | | | | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | in between the wheel tubs and the bed side it appears to be some kind of gasket? Is it replaceable or can you just bolt it back without replacting it? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I use Strip-Caulk by 3M, commonly called "dum-dum". Brian | | | | | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | what is strip caulk and where do you buy it? Do you buy it where you buy like bathroom caulking? Is it in the same type of tube? What color is it? | | | | | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | strip caulking where do you find it? What color is it? Is it in a tube like bathroom caulking and such? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Strip-caulk by 3M, for sale at real parts stores. Its a putty-like string-like stuff, its black. Used for sealing tailites on newer cars. In a cardboard box, blue & white. You might try a body supply store. Brian | | |
