| | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Everyone, After the cold dummy light goes off I got a short time of quick acceloration from a dead stop. After that, she takes a little longer to get up to speed. I've been told this will happen if the coil is going bad. :confused: Any ideas?
My truck don't leak oil, it just marks its teritory.
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | What is a cold dummy light?
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | In the early 60s, Chevy had an idiot light that was on when the engine was cold. Located next to the hot light, but it was green. Owners manual said that you were to take it easy whenever the cold light was on.
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | uhhhh... you're supposed to take it easy when that light is on? I just make sure the thing will idle properly and stomp and go... I thought it was the 'get going' light!  Kinda like the bottom of the Christmas tree at the strip.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Chevyboy,
Do you have a V8 or six? IF V8, do you have an air cleaner with a preheater stove on one of the manifolds? Make sure the diverter valve is opening (it is either thermostatic or vacuum controlled). It sounds like maybe your intake charge gets too hot and you are loosing power because of it, or the choke is not opening all the way. Otherwise check the coil. What carb are you running? If it is a quadrajet there is a lockout to prevent the secondaries from opening unless the choke is open all the way.
If it is a six, make sure the manifold heat diverter valve isn't stuck closed.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Everyone, My truck is running a 235, and it has a rochester carb. Is the heat diverter valve the heat riser on the exhaust manifold? What should the ohms, or voltage be if the coil is good?
