1 members (Otto Skorzeny),
89
Mod | | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | what works the best for cleaning an engine.Ive got a v-8 with pluged oil return holes.A quart of diesel in the oil,kerosene,trany fluid? Thanks,Ron.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | I once knew a guy who ran his packard with only kerosene in it about twice a year. I would'nt run it with anything but oil in it. Can you get to the holes with an air hose? If you can you might soak some penetrating oil in it for a few days and the blow it out. I have never had that problem so I am just guessing. Good luck.
I like old trucks
| | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Chevy V-8? The only holes that clog up routinely are the ones on both ends of the cylinder heads, and you can reach them by removing the valve covers. Just poke them clear with a piece of dowel rod and scrape the gunk away that's accumulated under the covers. While you're in there, replace the valve guide seals. One with enough mileage to clog the drain holes probably has totally worn out guide seals to go with it, and it will smoke like a freight trrain every time it's started. After the worst of the crud is removed by hand and the valve covers are back on, add a quart of kerosene to the oil and run the engine for 30 minutes at 1,500 RPM. DON"T DRIVE IT! Any load on the engine with solvent in the oil will burn rod bearings. Jerry
| | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Marvel mystery oil is a favorite of mine. Provides a good lube and excellent cleaner at the same time. Not the most expensive option either. I like to run some over the top of a fresh oil change to keep it clean too. | | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | All this works...Mavel mystery oil is really great stuff...so is Sea Foam | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Thanks guys.The truck is a 72 ford with a 390 with 90 thousand miles.I had the valve covers off before and was able to forse a wire rod through 3 of the 4 return holes in the heads.Im atempting to get it back on the road for my 16 year old son to drive.It smokes like a pig onse the head fills with oil.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Get a long drill bit, and a variable-speed drill motor, and ream those holes out. Then use a can of Wynn's "Engine Cleaner" in the oil, and run it for 30 minutes or more at a fast idle. Drain it while it's hot, and change the oil and filter. You'll need to install new valve guide seals to minimize the oil consumption. Jerry
| | | | | Joined: Sep 2004 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 46 | Whatever you do DO NOT use a product called "engine restorer" - don't remember the brand- I ran it through my '62 Nova before taking apart the motor, I could taste, smell, and feel it for two weeks. No substitute for serious scrubbin. Good Luck and Godspeed. Jeff
220 - 221 whatever it takes
