10 members (Gdads51, klhansen, Bill Hanlon, cmayna, tclederman, qside, Hanks custodian, mick53, 1955 1 Series, ShopRag),
115
Mod | | | Forums66 Topics128,268 Posts1,058,384 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 2,213 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,213 | Has anyone tried "Silent Running" to control sound? I was thinking of painting it under the hood and inside the doors. Silent Running Gord
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Looked at their site..looks interesting, but don't see any dealers, so guess you have to order from the factory...wonder what the $'s could be..sounds better than sliced bread, kinda makes me wonder | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | There have been other threads about the roofing material that comes in like 6" x 25' rolls available at Home Depot... I used it on my doors and floor... works well. And probably a lot cheaper. Did not use it under the hood tho. | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | The local marine supplies place carries it. I like the idea of painting it on - the other stuff may become unglued and catch fire.
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Gord - it might help in areas where part of the problem is 'drumming' - imperceptible vibrations that create sound [that's what the stuff is actually made for] not sure how much it would do for 'road noise', like from the tires and engine turning, and air rushing under the truck, etc, which is a large part of the noise we all want to eliminate - would be good on the roof of a panel truck I think, and might make the doors sound more 'solid' when you slam'em!! which is to say it's a vibration dampner more than sound insulation
Bill | | |
