6 members (Woodcmiami, MNSmith, Otto Skorzeny, Guitplayer, Lostbuthaulinass, Gray_Ghost), 61 guests, and 1 robot.
Topics128,057
Posts1,055,812
#169663 04/24/2005 9:00 PM
Insomniac
Insomniac
Has anyone tried "Silent Running" to control sound? I was thinking of painting it under the hood and inside the doors.
Silent Running
Gord
Gord 🇨🇦
1954 1/2 ton 235 4 speed
#169664 04/24/2005 10:04 PM
Looked at their site..looks interesting, but don't see any dealers, so guess you have to order from the factory...wonder what the $'s could be..sounds better than sliced bread, kinda makes me wonder
#169665 04/25/2005 12:53 PM
There have been other threads about the roofing material that comes in like 6" x 25' rolls available at Home Depot... I used it on my doors and floor... works well. And probably a lot cheaper. Did not use it under the hood tho.
Larry Bear
55.5 Chevy 3100 Panel
#169666 04/25/2005 6:45 PM
The local marine supplies place carries it. I like the idea of painting it on - the other stuff may become unglued and catch fire.
Gord
#169667 04/25/2005 8:04 PM
Gord - it might help in areas where part of the problem is 'drumming' - imperceptible vibrations that create sound [that's what the stuff is actually made for] not sure how much it would do for 'road noise', like from the tires and engine turning, and air rushing under the truck, etc, which is a large part of the noise we all want to eliminate - would be good on the roof of a panel truck I think, and might make the doors sound more 'solid' when you slam'em!! which is to say it's a vibration dampner more than sound insulation
