7 members (52Carl, Goach2, Hotrod Lincoln, Oswald, Hugh63c10, TUTS 59, cmayna),
140
Mod | | | Forums66 Topics128,204 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 33 Member | | Member Joined: Apr 2004 Posts: 33 | i have a "52 chevy here i need new springs and i am having tough time tracking some down. i say it may be a '51 because when i redid the brakes we found that the front end is '49 - '51, the frame is welded together, i guess it was in a wreck at some point. any ideas? | | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Try www.chevyduty.com. They might have what you need.  To compare prices, also check www.americanclassic.com, as they again may have what you want. (Nice looking truck!) | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I have some listed in the swap meet. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You can also try a local spring shop, usually one that works on trucks can make a set.
Fred 52 3600 69 C-10
| | | | | Joined: May 2004 Posts: 96 Member | | Member Joined: May 2004 Posts: 96 | Very cool! Would love to see more photo's. Reminds me of what the milk would have been delivered in, before my time  Do you plan on restoring to original look? | | | | | Joined: Apr 2004 Posts: 33 Member | | Member Joined: Apr 2004 Posts: 33 | thanks for all the suggestions, i will resume my search this weekend! the closest spring shop is an hour and 1/2 away and they want to have the springs in their hands to make another set, this is my only vehicle so that option is out. krissly - yes i am working on restoring it to nearly original, not quite so spartan on the inside tho' my family wants to ride in comfort. after the springs is the body work, she lists to port (or starboard - passenger side) i had the indignity of being rear-ended by a beetle bak in '89. so after the new springs i'll know for sure how far she leans because of springs and how far she leans because of a possible frame problem. | | |
