| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | When I bought the '47 panel I was handed a heater for it. (It had "50 Chev" in paint marker written on it.) When I compared the heater to the truck I found that it was not configured the same as the holes in my firewall.
The alleged "50 Chev" heater has the hose fittings in a horizontal line with the electric motor. The fittings are about a foot or so apart with the motor in the center. The holes in my firewall have the hoses coming in below the heater motor, about 4 inches apart.
I got in touch with a guy in the swap meet with an AD heater and he sent me a picture of the same thing I already have. I really do not want to make more holes in the firewall because this is a temporary solution until I get to a more modern system anyway.
Was there a change in the heaters or am I looking at it wrong?
What is the purpose of the large hole in the firewall? It does not appear that the heater motor protrudes through it. Is there supposed to be an inspection/service cover there?
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | There were at least three types of heaters used in the 47-55.1 trucks. The one called the Fresh Air Heater had the motor housing protruding from the back side. This is what went through the big hole in the fire wall. Models that used other heaters had a block off plate covering that hole. The fresh air heater mounted to the inner cowl panel and drew air in through the louvers on the right side outer cowl.
"That is all I will say about that" - forrest gump | | |
