0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#169271 05/31/2005 2:26 AM
Junior Member
Junior Member
Hello everyone. I is the new (old) kid on the block. Just got a 64 short wide running project. Has a 283 and Turbo 350, late model 5 lug axles transplanted in the rear. Next up is 5 lugs in the front. Any low buck suggestions? Thanx
#169272 05/31/2005 3:07 AM
welcome to the bolt,, you belong to a great site and full of good responses,,,,Fred
Redryder pix
My Hotrod
#169273 05/31/2005 3:14 PM
Junior Member
Junior Member
Welcome! Low buck... You speak my language! I aint cheap but been there done that with the shiney stuff. DP90 or rattle can flat black is my choice for now.
Norm - "The Grumpster"
Crew-zin a 64 Chevy C20 Crew Cab
http://www.grumpyzgarage.com
#169274 05/31/2005 3:51 PM
Welcome to the Stovebolt!
I'be seen the complete IFS from a '72 to '87 swapped under a '63-'66 gaining slightly newer suspension with 5-lug disk brakes. That could be pretty low buck if you find the parts cheap enough.
#169275 06/01/2005 4:32 AM
Z
Z Offline
the 73-87 c10 crossmember and steering mostly bolts in.
