0 members (),
77
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1 Junior Member | | Junior Member Joined: May 2005 Posts: 1 | Hello everyone. I is the new (old) kid on the block. Just got a 64 short wide running project. Has a 283 and Turbo 350, late model 5 lug axles transplanted in the rear. Next up is 5 lugs in the front. Any low buck suggestions? Thanx | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | welcome to the bolt,, you belong to a great site and full of good responses,,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2005 Posts: 15 Junior Member | | Junior Member Joined: Jan 2005 Posts: 15 | Welcome! Low buck... You speak my language! I aint cheap but been there done that with the shiney stuff. DP90 or rattle can flat black is my choice for now. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Welcome to the Stovebolt!
I'be seen the complete IFS from a '72 to '87 swapped under a '63-'66 gaining slightly newer suspension with 5-lug disk brakes. That could be pretty low buck if you find the parts cheap enough.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | the 73-87 c10 crossmember and steering mostly bolts in. | | |
