1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#16883 10/29/2003 5:25 AM
Q
Q Offline
I used to post using the name Smokin54 some of you may remember me , I dont have the old email address or pass word.
Due to a lack of funds the ol 54 3100 has been stored for a few years and I have been off line, It looks like things are getting better and this weekend I am going to change the oil in the motor and give the oil pump a good spin to get some oil moving and then I want to fire up the motor .
Are there any other suggestion for firing up a tight motor that has sat for a good while ?
This motor was rebuilt and then driven maybe 20 miles before i was forced to park my truck .
The project will now begin to move forward again at last !!!!!
#16884 10/29/2003 7:02 AM
Welcome back to the `Bolt cool
Looking forward to driving it again I bet grin
#16885 10/29/2003 2:03 PM
Crank it for 45 seconds with the coil wire off to pump up the system and get the oil up top and the fuel forward. Also, you should drain the tank and refill it with fresh gas.
#16886 10/29/2003 3:37 PM
Since you're spinning the oil pump, you don't need to crank on the engine to lube the bearings. But I would give each cylinder a squirt of light oil and spin the engine. Helps seal the rings and prevent scored cylinders.
Fred
52 3600
69 C-10
#16887 10/30/2003 12:27 AM
And when you are done, you must tell us all about it so that we can all celebrate. I am glad that things are looking up for you.
1951 1 Ton Completed
#16888 10/30/2003 1:21 AM
welcome back to the bolt,, good luck on your 54,,,Fred
Redryder pix
My Hotrod
