2 members (carbking, TUTS 59),
108
Mod | | | Forums66 Topics128,029 Posts1,055,416 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 17 New Guy | | New Guy Joined: Mar 2005 Posts: 17 | When I took the window frames out of my 1950 GMC pickup there was weatherstripping (windlace?) stapled through the frame. I have cleaned and painted the frame, now I wonder what kind of tool or process to use to re-attach new weather treatment to the window? | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I had the same issue with my 56 when I was doing the refelting. I was able to salvage a few of the 'staples' by carefully prying up each pointed end of the staple. When installing the new felt the staples pierced thru well enough then I hammered them back down. Where I couldn't reuse the staples I used rivets. Worked OK. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | My 64 had some spots on the fender seals etc. that were stapled, I used Arrow T50 staplegun staples. Installed them w/needlenose pliers into the original holes. Brian | | | | | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | small flathead screws will work. the smallest size i could find was 1/2 inch #6. when you tighten them down, they will bury themselves in the felt | | | | | Joined: Mar 2005 Posts: 17 New Guy | | New Guy Joined: Mar 2005 Posts: 17 | Good ideas, They must have really had a powerful staple gun at the factory. Those window frames seem pretty tough. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The T50 staples line up real good w/the original holes, I'm guessing they used some type of air powered job. Brian | | |
