1 members (sron48), 124 guests, and 4 robots.
Topics128,164
Posts1,056,966
Members48,458
#168719 03/21/2005 3:35 AM
When I took the window frames out of my 1950 GMC pickup there was weatherstripping (windlace?) stapled through the frame. I have cleaned and painted the frame, now I wonder what kind of tool or process to use to re-attach new weather treatment to the window?
1950 GMC 100
This truck is for sale
More pictures in Photobucket
#168720 03/21/2005 12:59 PM
I had the same issue with my 56 when I was doing the refelting. I was able to salvage a few of the 'staples' by carefully prying up each pointed end of the staple. When installing the new felt the staples pierced thru well enough then I hammered them back down. Where I couldn't reuse the staples I used rivets. Worked OK.
Larry Bear
55.5 Chevy 3100 Panel
#168721 03/21/2005 3:22 PM
My 64 had some spots on the fender seals etc. that were stapled, I used Arrow T50 staplegun staples. Installed them w/needlenose pliers into the original holes. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#168722 03/21/2005 4:13 PM
small flathead screws will work. the smallest size i could find was 1/2 inch #6. when you tighten them down, they will bury themselves in the felt
#168723 03/21/2005 11:16 PM
Good ideas,
They must have really had a powerful staple gun at the factory. Those window frames seem pretty tough.
1950 GMC 100
#168724 03/22/2005 5:19 AM
The T50 staples line up real good w/the original holes, I'm guessing they used some type of air powered job. Brian
