| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16859 10/23/2002 2:01 AM | Joined: Feb 2002 Posts: 22 Member | | Member Joined: Feb 2002 Posts: 22 | yes you can order rims from a quality supplier with any backset you want, ie the bolt face close to the front of the rim close to the back of the rim, but if running stock steering make sure the inside edge of the tire will not interfer with the pitman arm....some people heat and bend the arm but it is cast so be careful. | | |
