3 members (lumbersawyer, tclederman, 1 invisible), 70 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#168528 12/31/2004 9:54 PM
I was lucky enough to get new "orig. style" door mirrors/arms for the '59 for Christmas and although the driver's side door had the orig. mounting holes/tap plates, the pass. door does not. does anyone know if the "correct" location for pass. side is a (pardon the pun)mirror image of the drivers side?
Thanks and Happy New Year to All,
Jeff
220 - 221 whatever it takes
#168529 12/31/2004 10:02 PM
Thats the way I mounted the right,(passenger) side mirror on my 55.I believe the curve on the right was different from the left side.
#168530 12/31/2004 11:33 PM
to find the right location to drill thru the door skin, take off the inner panel and look inside - there's the same plate attached in there as on the drivers side, and yes it's about same position, w/ a slightly different shaped arm
