| | | Forums66 Topics128,023 Posts1,055,365 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 46 | I was lucky enough to get new "orig. style" door mirrors/arms for the '59 for Christmas and although the driver's side door had the orig. mounting holes/tap plates, the pass. door does not. does anyone know if the "correct" location for pass. side is a (pardon the pun)mirror image of the drivers side? Thanks and Happy New Year to All, Jeff
220 - 221 whatever it takes
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Thats the way I mounted the right,(passenger) side mirror on my 55.I believe the curve on the right was different from the left side. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | to find the right location to drill thru the door skin, take off the inner panel and look inside - there's the same plate attached in there as on the drivers side, and yes it's about same position, w/ a slightly different shaped arm
Bill | | |
