| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | I almost flung my barn door glass across the shop!! I just can't get the new rubber in. I got the new seal from Chevy Duty. Has anyone put the new stuff in without any problems?? Any tricks? I'm using the soapy rope. I just can't get it to go. Thanks Guys.
Jim S. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Two people, rope/string, and plenty of K-Y Jelly (or generic equivalent) on the rubber seal? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I've never done a barn door, but I've done the windshield and rear glass. It takes a bit of patience. First of all, you need glass that actually fits. A lot of times it is a bit oversize from repeated tracings of original glass, and it won't fit no matter what you do. Hopefully yours isn't.
Second, you need rubber that actually fits. Steele is the very best. I used Chevy Duty's rubber this time and it went ok. You need to do it on a warm day so the rubber is nice and pliable. Leave it in the sun for a few hours.
When you have the glass out clean the pinch weld really well and apply a coat of your favorite caranuba wax. This will both protect the paint and make the rubber slide easily.
Put the rubber on the glass first, and when you put it in the door, start with the tightest radius curves (bottom on the windshield) first. They are really tough to get around when the glass is in there tight. Wrap a piece of parachute cord all the way around in the rubber. Overlap it a little, even. Have your helper hold the glass in place from the outside. I was able to do the windshield by myself but I have long arms and a good vocabulary of swear words.
Use a putty knife to assist you for when the string isn't getting it, and use it to relax the rubber once it gets over the pinch weld. Take your time working the rubber over the flange, it tears easily if you pull too hard with the rope. Slowly zip the cord around, pulling the seal over the pinch weld and using the putty knife to coax it into place. If things are going badly, pull it out and start over.
I save the sealant to the last step, using the very narrow tip of the caulk gun to force it under the rubber until it oozes out. I have not had any luck applying it before putting in the glass.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | here is an alternate method. Go to the local glass shop. Ask for their best and oldest widow installer. Ask him what his favorite beer is. Tell him there is a case of said beer in your fridge and it is his if he would be willing to come over and teach you how to install said window. You might want to have some cash on hand too.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Apr 2004 Posts: 219 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 219 | A lot of times it is a bit oversize from repeated tracings of original glass, and it won't fit no matter what you do. Hopefully yours isn't. ---------------------------------------------
I think this was the culprit. I've used the rip cord method in the past with no problems. I never thought of the glass tracing thing. Good call!! It just wouldn't fit in the opening with the glass in place. The seal didn't fit over the glass far enough to allow it to slip into place.
[QUOTE]Originally posted by Brian Moore: [QB]here is an alternate method. Go to the local glass shop. Ask for their best and oldest widow installer. Ask him what his favorite beer is. Tell him there is a case of said beer in your fridge and it is his if he would be willing to come over and teach you how to install said window. You might want to have some cash on hand too.
This is what I did. The installer did a great job with lace & urethane. I'll get some photos & post them on my WebShots. Looks great! Fits in nice & flush. Thanks for the replies Guys.
Jim Sgrig | | |
