| | | Forums66 Topics128,035 Posts1,055,552 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16722 08/09/2004 5:30 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | How do I replace the front motor mount rubber support? The manual says to loosen the rear mount, but doesn't say just how the remove the front mount. Do I jack up the motor?
Winona 1949 3100 5 Window Deluxe Cab
#16723 08/09/2004 8:17 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Best way I have found is to put a block of wood under the balancer and jack the engine. If the jack or block is in your way, block up the engine under the oil pan to move the jack out of the way. Use large blocks, you can cave in the oil pan, but that's not much of an issue on these trucks, the pan is fairly rigid.
Fred 52 3600 69 C-10
