4 members (TUTS 59, dt235sd, cmayna, 1 invisible), 70 guests, and 4 robots.
Topics128,176
Posts1,057,122
Members48,463
Hi,
Still looking at that 46. I heard it run, but owner had to pour gas in carb to start..He said carb was bad..It has a Zenith carb on the 261 Chevy engine. I was wondering where and how much a rebuild kit would run me..
http://www.clgw.net/~tonyp
ParrTony Jim Carter has them www.oldchevytrucks.com Dave
I think that if it is the old style motor with the sheet metal side cover that includes the spark plug area, you are looking at a 216, not 261.
1951 1 Ton Completed
Double checked the motor...owner said it came from a larger truck (chevy)..the 261 is not orginal in the 46. I have a 235 from my 54 and I have the trans from it also since I'm doing some modifactions on the 54, I heard that all this would fit nicely in the 46, but I needed a carb on 46 to drive it down road..for the price he is asking I wanted to drive it first..
As far as I know, no 261's had Zenith carbs, they were Rochester B's, unless you have one that is an updraft model. One could have been transplanted from a GMC, though. The 261 uses the same bolt pattern as a 235 but bigger jets in the carb. Are you sure this guy isn't pulling your leg? You mentioned in another post that this was a babbit motor. All 261's were full pressure insert bearing engines. If it is post- '57 it will have a full flow oil filter with 1/2" NPT lines.
Paint & Body Shop moderator
