1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | I struggle installing the stock seat in my '42 PU...It is always difficult getting the back cushion hooked through the top slots and while getting the bottom tongues lined up to go through the slots on the back of the bottom cushion...then keeping them all together while you push the whole seat in place. Is there a trick to this? Am I missing something?...I'm a tired old man and need help! | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | I have put my seats in and out a lot and once I line up the bottom seat where it goes I just put the back so that the tabs go in the slots and push straight down. It goes right into the bottom with no issues. Are the top tabs or bottom posts bent on the back of the seat?
It should go fairly easy.
1946 Chevy Pickip
| | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Are the tabs and posts supposed to be bent? Mine are. | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | I guess I should have clarified that...they are angled but I guess you wouldn't know if they were bent.
I should have time Saturday to pull my seat out and post up a picture of the rear seat for you.
If you put the top tabs in the slots the bottoms should really just line right up for you.
1946 Chevy Pickip
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Gosh Zipper, I'm just glad the Goose is helping me on my way to total confusion. Nest (next ha ha) week my seat should be ready to wrestle with. Any pictures you could post of a properly operating seat insertion, bent or unbent, would be greatly appreciated. LMAO but thankful at the same time.
SteveG, you post pix too. You to Kips'41. We are all in this together.
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | pictures will be up by end of day tomorrow. Had a busy weekend and haven't made it out to the garage to even drive the truck.
1946 Chevy Pickip
| | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | oh yeah...when you mount your brackets under the seat above the gas tank two of them have round knobs that stick up. They are to line up the seat bottom when you put it on. On the front of the outside seat frame are two holes. When you set that seat bottom in place using those the rear should just set right in.
1946 Chevy Pickip
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Thanks a lot zipper. Just one question... what are those two alien cone shaped things mounted in a box behind the seat? Just kidding!  My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Thanks, Zipper, my seat hardware is exactly the same. Do your top cushion hooks slip all the way into the top slot? | | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | Originally posted by steveg: Thanks, Zipper, my seat hardware is exactly the same. Do your top cushion hooks slip all the way into the top slot? Honestly I am not sure since I cant see them when the seat is down and in place. But I cant push down any further with the seat and it all locks into place tightly.
1946 Chevy Pickip
| | | | | Joined: Jul 2005 Posts: 161 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 161 | Originally posted by down2sea: Thanks a lot zipper. Just one question... what are those two alien cone shaped things mounted in a box behind the seat?
Just kidding! So I can have some Ray Charles cranking while I am cruising along.
1946 Chevy Pickip
