7 members (Shaffer's1950, 54farmtruck, Southerntruck, Lightholder's Dad, Pre '68 Dave, Donf, rfs56trk),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16631 01/29/2004 4:10 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | My GMC 302 six starts very easy but pings on acceleration. Does this mean it is too far advance or retarded. The motor is not broken in so I'm worried about damage to the cylinder walls. I guestimated the RPMs when setting the timing. Do I need a tach to get it right?
And what the hey is a Petronix?
Thanks guys | | |
#16632 01/29/2004 4:18 AM | Joined: Jan 2004 Posts: 7 Member | | Member Joined: Jan 2004 Posts: 7 | Well, First Lets Answer A Few Questions.Does The Truck Have Good Fresh Gas??Is Your 302 A Fresh Rebuild??Is Your Vacuum Advance Plugged When You Time It??What Are You Setting The Timming At?? And To Answer Your Question On The Ping.You Must First Answer These Questions.If You Answer YES On All The Above The Answer Is Yes It To Far Advanced.10-4 GMCJOHN
JB
#16633 01/29/2004 3:10 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Whats your compression ratio? Pinging can be from too much timing, or too little octane for compression ratio. You running high-octane gas? Rule of thumb is the octane you need is 10 times the compression ratio. If you've got 9:1 compression, you need 90 octane gas.
Timing should be set with vacuum advance disconnected and vacuum source plugged. With motor at slow idle, set base timing for about 10 degrees BTDC and see how it runs. Is your advance mechanism free, lubed and working correctly? The mechanical advance mechanism is what controls spark advance above idle. Too much and she'll ping and detonate, to little and she'll run like crap.
Petronix is a replacement for points. It fits inside the stock dist in place of points, and uses a magnet and hall-effect sensor with signal amplifier to trigger coil. Costs about 80-100 bucks for the system, hook up 2 to 4 wires and go. I've got one in a 235, and its great.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#16634 01/29/2004 9:02 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | You also may need to limit the travel of the vac advance to stop it from pinging. Some of the replacement vac advances today allow too much advance.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#16635 01/31/2004 3:28 AM | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | Thanks guys for the primer on timing. You've answered my questions but I can't answer many of yours. I gotta confess that my mechanic actually timed this particular truck and my original post was based on past experience with my old GMC from 20 years ago.
It does have fresh gas in a vatted gas tank, don't know compression ratio, it has about 80 miles since a complete rebuild (which I don't know much about since this motor is an Ebay adventure), I'm thinking the idle was high (1200 RPM per Tach)when they set it because I had to back off the idle screw. I assume the vacuum advance was disconnected and the source plugged cause even though this guy is kind of "shade tree" (which is a good thing), he's cheap.
Anyway, you've addressed my main concerns which were: I don't need a tach to set timing, just low idle. Pinging means it may be too far advanced. A Petronix point replacement is worth getting.
Thanks again | | |
#16636 02/01/2004 10:26 PM | Joined: Nov 2003 Posts: 39 Junior Member | | Junior Member Joined: Nov 2003 Posts: 39 | I don't think a tac is necessary. I usually don't use a timing light. Started "timing by ear" about 25 years ago and used my light very little since. Try it, drive it and if necessary readjust it, this is easy when you know the vehicles.
There is no mechanical problem so difficult that it can not be overcome by brute force and ignorance.
