3 members (ShopRag, dt235sd, 1 invisible),
359
Mod | | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16516 07/20/2004 3:47 AM | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | If some of you can remember, back in Jan of this year I was restoring a '53 front axle assy to replace the tired setup in my '50. After a few detours I finally was able to install it this month. Jan-Powder coated and extra set of axle and spindles, restored, repainted leaf springs and hubs.New king pins modern tie rods and modern ends, new modern steering connecting rod new brakes pads, cylinders and SS brake lines. Then they sat. Spring time-Replaced 4:11 gears in the back with Patrick's 3:55. Followed by new rear brakes, cylinders, restored leaf springs. This month - Removed old front axle assembly along with old spring leafs, tie and connecting rods. Replaced main bearing seal, timing cover gasket and seal, side cover gasket, oil pan and valve cover gasket. Tightened up the steering box. Finally installed the Jan project with new rods and shocks, etc. Tonight my daughter helped me bleed the brakes, install the wheels and off we went on our test drive. Unbelieveable ride. It has never driven so tight and smooth. Even my daughter said during the maiden voyage "Dad, what happen to all those bumps and shakes ?" I appreciate all the input you guys gave during my various projects. Mechainiac, that pitman arm is Craig
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#16517 07/20/2004 5:07 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | :confused: Craig - Tell us about the pitman arm???
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#16518 07/20/2004 1:54 PM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Craig,
Congratulations. All your work is paying off.
Tim | | |
#16519 07/20/2004 3:22 PM | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | 6cyl, Since I was installing new modern style tie rod, ends & steering rod, I could not use my original pitman arm which has a ball, so Mechianiac was kind enough to send me an extra of his which was missing the ball. Fit just perfectly.
I also must admit that I successfully cheated when bleeding the front brakes and never having to touch the rears. First drivers side and then passenger side.
And the creame de la creame was the results of front shoes adjustment. Initial serious stomping on the pedal with no hands on the wheel while traveling down a quiet road. It stayed straight. In the years I've owned this truck it has alway leaned towards the left. Even my brake bleeding helping daughter was impressed.
Maybe this is all a dream. If so I hope never to waken.
#16520 07/20/2004 3:46 PM | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Craig-
Hard labor yields just rewards. An your daughter got a ring-side seat for that lesson. You'll grin ear-to-ear every time you turn the wheel! | | |
#16521 07/20/2004 4:38 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | craig thanks for the update! Good job!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#16522 07/20/2004 7:16 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Congratulations, Craig. You sure did a lot of work! And that means you're experiencing a lot of positive changes ... what a joy, eh?
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#16523 07/20/2004 7:37 PM | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | The next two major projects are a paint job and replace wire harness. I think I'll just relax and enjoy the ride for awhile, doing some other household projects such as finishing up my back patio, etc.
I really learned a lot and hope I can find another chevy such as a BelAir to work on....
#16524 07/20/2004 10:46 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | This shows you don,t need all these hi-doller front clips to make them drive good. Just get everything in good shape. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#16525 07/20/2004 11:10 PM | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Way to go Craig! Riding high and proud, and "I did it myself with a little help from my friends (and family)."
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#16526 07/21/2004 7:05 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 |
#16527 07/21/2004 1:44 PM | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | Craig, I have enjoyed reading your progress. I to re-built the front end on my '51 GMC this spring and have really enjoyed the ride. Have a question about the steering box. Mine still has a bit of play and I have not yet done the adjustment. Did you rebuild yours?Tom | | |
#16528 07/21/2004 2:10 PM | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Thomas, I did not rebuild it, though I probably should have. I instead just adjusted & tightened it up. With the pitman arm disconnected I was able to turn the steering wheel with no resistance showing on my hand held fishing scale. It took me a couple attempt to get to the 1 1/2 - 2 # range.
#16529 07/23/2004 5:53 PM | Joined: Nov 2002 Posts: 55 Member | | Member Joined: Nov 2002 Posts: 55 | Craig,
Ok, I'm inspired now. I was debating whether to rebuild the front end on my 56 3100 or just put the engine back in and drive it, but your post has made my decision.
Given the choice between spending a few more months working on the truck vs. driving it and wondering how worn out my steering/suspension is, I'm choosing more work now and peace of mind. LT | | |
#16530 07/23/2004 11:53 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Rebuilding the front end is one of the most rewarding things you can do and isn't terribly difficult. It was one of the first things I did on my truck.
I just finished an R&R on the entire suspension of my '89 BMW. Talk about a differance, the shocks were leaking and the thing would shimmy and thump on bumps and brake applications. With new ball joints, tie rod ends, control arm bushings, and shocks, it rides and feels like new and is perfectly quiet.
#16531 07/24/2004 2:15 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Craig, did your motor have a rope seal or a neoprene one ?
Fred | | |
#16532 07/24/2004 2:33 AM | Joined: Jan 2002 Posts: 2,843 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,843 | Neo' So I replaced it with same. I know some of you are saying "tish, tish, tish" but I want to give it a try.
#16533 07/24/2004 12:10 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | They are so much easier to deal with and that is what the modern engines use. It sounds like you have a new truck! Knowing that you did all the work must be very satisfying. | | |
