6 members (Lostbuthaulinass, klhansen, Otto Skorzeny, Charles in CA, Peggy M, Gray_Ghost), 114 guests, and 2 robots.
Topics128,059
Posts1,055,825
#165117 12/17/2006 6:59 AM
Can someone tell me how the lower (stock) seat fastens to the seat frame on a '42?
#165118 12/18/2006 6:08 PM
If your 42 is same as my 40, lower seat assembly sits over 2 pins sticking up from bars that mount across the gas tank surround frame. Seat & seat back are 1 piece. Seat back has clips that slide over brackets on the rear of the cab
1940 Chevy KC 1/2-Ton
#165119 12/18/2006 8:20 PM
Thanks, Bruce. I'll bet they're the same. I'll look a little closer. It seems that the pins may be missing.
Mike.
#165120 12/18/2006 10:50 PM
Yes that is how they go together. I have a 42 also. If you need the two bars with the pins let me know.
The crew that works on the \'42 --Sara, Hannah and Abby
#165121 12/19/2006 2:15 AM
Ok, I'll check and let you know. Thanks alot.
Mike.
Moderated by  ndkid275, Phak1
