| | | Forums66 Topics128,057 Posts1,055,810 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | Can someone tell me how the lower (stock) seat fastens to the seat frame on a '42? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If your 42 is same as my 40, lower seat assembly sits over 2 pins sticking up from bars that mount across the gas tank surround frame. Seat & seat back are 1 piece. Seat back has clips that slide over brackets on the rear of the cab | | | | | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | Thanks, Bruce. I'll bet they're the same. I'll look a little closer. It seems that the pins may be missing. Mike. | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Yes that is how they go together. I have a 42 also. If you need the two bars with the pins let me know. | | | | | Joined: Nov 2006 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 96 | Ok, I'll check and let you know. Thanks alot. Mike. | | |
