8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#165109 12/16/2006 7:52 PM
Ok thanks for the help on getting the gauge cluster out, now I need to replace the needle that broke off leaving only pieces. Just how is the needle replace? I see the rod were the needle would go and there is a green cap on the end of it however I don't know if this cap should come off or not and am afraid force it.
#165110 12/16/2006 9:17 PM
yes it comes off - should be part of the needle, as you'll see when ya get a new one - grab the shaft w/ a pair of long nose pliers and pull the old one off .... carefully, so ya don't bend the shaft
#165111 12/18/2006 2:44 PM
I just removed a needle a couple weeks ago. I was really surprised how tough it was to pull it off! I didn't hurt the shaft, but the old needle was completely junk by the time I finished yanking on it. Take that as caution for when you install the new needle on the shaft.
Anyone know why it is possible to buy a new cluster, complete with the speedo/odometer (~$125) but not ONLY the speedo/odometer works?
#165112 12/18/2006 3:32 PM
thanks for the help, got it off. odometer cleaned up nice with mild soap and water.
Dan
Moderated by  ndkid275, Phak1
