2 members (RLB, Guitplayer),
139
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | Ok thanks for the help on getting the gauge cluster out, now I need to replace the needle that broke off leaving only pieces. Just how is the needle replace? I see the rod were the needle would go and there is a green cap on the end of it however I don't know if this cap should come off or not and am afraid force it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes it comes off - should be part of the needle, as you'll see when ya get a new one - grab the shaft w/ a pair of long nose pliers and pull the old one off .... carefully, so ya don't bend the shaft
Bill | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I just removed a needle a couple weeks ago. I was really surprised how tough it was to pull it off! I didn't hurt the shaft, but the old needle was completely junk by the time I finished yanking on it. Take that as caution for when you install the new needle on the shaft.
Anyone know why it is possible to buy a new cluster, complete with the speedo/odometer (~$125) but not ONLY the speedo/odometer works?
Bill | | | | | Joined: Oct 2006 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 111 | thanks for the help, got it off. odometer cleaned up nice with mild soap and water.
Dan | | |
