| | | Forums66 Topics128,164 Posts1,056,968 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | I know it sounds frivolous but does anyone know the machined screw size that goes on the interior door handles, window cranks and door locks on the 41 to 46 Chev. I see Carters has them for the interior door handles but that seems to be all I could find. A 9/32 fits but it seems a little loose in there. Bob T | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bobt, Deja vu! http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=003731#000000 Stuart | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Thanks for the info. Looks like your right, I tried 1/4 inch allan and they wouldn;t work but the 10/32 seems to work but is pretty tight. Sorry bout the DejaVu but up here we have to deal with mostly metric which to us old guys is a real pain trying to find a proper SAE size. thanks again. Bottom line was I was going to retap but I don't need to now.Bob T | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not sure bout the 46 but I'm working on my 1950 right now and the are; 1/4”-20 tpi x 1/4”lgt. Dog point for the set screw and 1/4”-20 tpi x 1/2”lgt. Fillister head for filler screw. Note the head on the filler screw is not the standard diameter of around .400”. It must be turned down to 5/16 to match the original. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | bobt
On my ’41 the ones that hold the window crank and inside door handle are #10-32 by 9/16” long. The one that holds the exterior door handle is a ¼-28 shoulder bolt with 5/16 of thread | | |
