3 members (baldeagle, Gray_Ghost, frogfarmer), 73 guests, and 12 robots.
Topics128,020
Posts1,055,345
Members48,419
#164452 06/19/2006 9:52 PM
I'm getting the seat and sun visors reupholstered in my '66 C-10. I removed the fabric covering the door panels and can't get the glue off. The current upholstery is roughly 20 years old. Any advice on getting the old glue off? I want to keep the paint on the panels since its going to be a few more years until I get the chance to fully restore the Green Machine. Thanks
Drew
#164453 08/11/2006 4:58 AM
Well first off let me say that I've never done this so I'm speculating based on what I've heard from other forums and people.
I've heard of people removing wood panel stickers by using a heat gun to heat up the glue underneath and pealing the stickers off. People have been very successful at doing this without damaging the paint underneath. You may be able to heat up the glue in this way and then scrap it off with a plastic putty knife or better yet use a mild bug and tar remover to remove the glue once heated. suggestion, wear gloves.
59 Fleetside Longbed-350 Crate
76 Jeep J20 Ambulance
2007 Wrangler X
#164454 08/21/2006 8:42 PM
I was reading "project old school" In Classic trucks magazine.
On the 65 they did, it said they had to use a wire wheel.
You might use a wire wheel and spay a light coat of primer to keep of the flash rust. When you get ready to paint it just sand off the primer.
#164455 08/22/2006 2:45 AM
wd 40 or goo gone.
64 c10
89 rs
62 econoline
50 ford coupe
#164456 08/23/2006 7:33 AM
I have used heat gun and razor blade on lots of graphics. If they are thick vynil that works very well. Just a bit hard on the hands with all that heat. On the Gravely Commercial 10 I just did, the graphics were too far gone, and I had to wire wheel em off.
#164457 08/24/2006 4:59 AM
66STEPSIDE you might try peerco 321 adhesive remover enviromentally freindly and works well.
Moderated by  ndkid275, Phak1
