| | | Forums66 Topics128,022 Posts1,055,352 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | I'm getting the seat and sun visors reupholstered in my '66 C-10. I removed the fabric covering the door panels and can't get the glue off. The current upholstery is roughly 20 years old. Any advice on getting the old glue off? I want to keep the paint on the panels since its going to be a few more years until I get the chance to fully restore the Green Machine. Thanks
Drew | | | | | Joined: Aug 2006 Posts: 13 New Guy | | New Guy Joined: Aug 2006 Posts: 13 | Well first off let me say that I've never done this so I'm speculating based on what I've heard from other forums and people.
I've heard of people removing wood panel stickers by using a heat gun to heat up the glue underneath and pealing the stickers off. People have been very successful at doing this without damaging the paint underneath. You may be able to heat up the glue in this way and then scrap it off with a plastic putty knife or better yet use a mild bug and tar remover to remove the glue once heated. suggestion, wear gloves.
59 Fleetside Longbed-350 Crate 76 Jeep J20 Ambulance 2007 Wrangler X
| | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I was reading "project old school" In Classic trucks magazine. On the 65 they did, it said they had to use a wire wheel.
You might use a wire wheel and spay a light coat of primer to keep of the flash rust. When you get ready to paint it just sand off the primer. | | | | | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 |
64 c10 89 rs 62 econoline 50 ford coupe
| | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I have used heat gun and razor blade on lots of graphics. If they are thick vynil that works very well. Just a bit hard on the hands with all that heat. On the Gravely Commercial 10 I just did, the graphics were too far gone, and I had to wire wheel em off. | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | 66STEPSIDE you might try peerco 321 adhesive remover enviromentally freindly and works well. | | |
